TwinTurbo.NET: Nissan 300ZX forum - The stalk does two things: pull to "flash", push to "on"
Subject The stalk does two things: pull to "flash", push to "on"
Posted by BobbyT on August 28, 2008 at 11:54 PM
  This message has been viewed 86 times.
In Reply To Highbeams won't turn off posted by cueball060 on August 28, 2008 at 10:31 PM
Message Every so often when I "pull" the stalk and release to flash the highs will stay on, but just pushing the stalk a little (not moving it, just a little pressure) makes them go off.
I don't think it's ever happened when I've moved the stalk from the forward ("on", not "flash") position back to normal, but I've heard of guys having the same problem then.
I've always just assumed it was sticking a little due to age...do you just flick the switch until it stops, or have you tried just putting light pressure on it to see if it makes/breaks contact?
